Reading csv files from FTP
hello,
i'm interested to know the usual process in reading/getting files from FTP caller.
I did make FTP caller run, however, I don't know the next transformers to use to read the csv (not in a zip file) from the FTP server.
I tried attribute splitter and list exploder, but didn't work.
Can you share a sample workbench for the same case, please?
Thanks!
david_r
  • July 13, 2022
My preferred way of doing it would be
  • TempPathnameCreator to create a temporary directory
  • FTPCaller do download the file into the temporary directory
  • FeatureReader to read the CSV file from the temporary directory
The temporary directory with its contents will be automatically deleted once the workspace terminates.
  • July 14, 2022
Hi @david_r​ , thank you so much for your feedback. However, I am super newbie here and I'm not sure how to work with those transformers. Do you have any sample workbench? thank you again!
david_r
  • July 14, 2022
Try something like the pattern in the attached workspace template.
  • July 21, 2022
thank you @david_r​ ! it works for me!
