Read xml that is complex nested then create(writer) relational database tables(one to many or many to many etc). But xml_parent_id is empty
  • November 10, 2021
  • 0 replies
  • 21 views
fmefragment2Inkedfragment_LI
Hi everyone,
I called wsdl address with httpcaller then I retrieve the response_body that is nested xml. So, I used attrıbutefilewriter(like reader) then I used featureReader and attributeKeeper for catching xml_id. Thus, my problem is xmlFragment I did not catch xml_parent_id for merging. Actually, real aim is "Is there any shortcut using xml_parent_id to establish the relationship between tables in the database after FeatureReader operation?"
Thanks.
