Wonder if there is a way to read Microsoft Planner (Microsoft Task) with FME ?
Yarko
Yarko
Best answer by sigtill
Hi @ukrsolid - One approach is to use the Microsoft Graph API towards the Microsoft planner. Its a bit tricky to set up - but then you have access to all Microsoft functions. (https://docs.microsoft.com/en-us/graph/api/resources/planner-overview?view=graph-rest-1.0)
Graph Api and how to set up: https://hub.safe.com/publishers/gerhardatsafe/web-connections/microsoft-graph
