Read Microsoft Planner with FME
  • Aug 24, 2020 10:36 PM UTC
  • 209 views
Forum|alt.badge.img+3
Wonder if there is a way to read  Microsoft Planner (Microsoft Task) with FME ?
Yarko
Best answer by sigtill
Hi @ukrsolid​  - One approach is to use the Microsoft Graph API towards the Microsoft planner. Its a bit tricky to set up - but then you have access to all Microsoft functions. (https://docs.microsoft.com/en-us/graph/api/resources/planner-overview?view=graph-rest-1.0)
Graph Api and how to set up: https://hub.safe.com/publishers/gerhardatsafe/web-connections/microsoft-graph
sigtill
Forum|alt.badge.img+25
  • Aug 25, 2020 7:24 AM UTC
  • Aug 25, 2020 3:30 PM UTC
Thanks @Sigbjørn Herstad​  I will give it a shot !
Yarko
pauldeq
  • Dec 19, 2023 4:03 PM UTC
@Sigbjørn Herstad​ Your Graph API and how to set up link does not work. Takes me to a page not found. Has this been moved? If so, what is the new link?
