Read directory of SDE connection files and list database and all feature classes, tables, etc. to create an inventory
  • Apr 20, 2023 8:39 PM UTC
  • 10 replies
  • 1053 views
jonvelco
Forum|alt.badge.img+7
My goal is to read a directory of SDE connection files and then list out the database name and all the feature class names, tables, geometry types, etc. associated with each connection file.
I've reviewed the articles below and can't figure out how to set the Feature Types to Read parameter since it only shows tables/feature classes from the one Reader as a Resource SDE connection. This isn't an issue if there is only one database but when there are multiple (like what I'm trying to do), it doesn't seem to work. Is this possible or is there another way to get this info?
Here are the articles I've been using:
https://community.safe.com/s/article/how-to-read-all-feature-classes-from-multiple-esri
https://community.safe.com/s/question/0D54Q000080hHCASA2/read-multiple-sde-connect-file
https://community.safe.com/s/question/0D54Q00008qzlJhSAI/how-to-dynamically-read-entire-schema-of-sde-geodatabase
hkingsbury
Forum|alt.badge.img+73
  • Apr 21, 2023 1:41 AM UTC
The way i'd approach it is using a FeatureReader with the directory being c:\\temp\\*.sde (read all files ending in SDE in that folder) then set the FeatureReader to only read the schema and process the output schema from there into the required format
jonvelco
  • Apr 21, 2023 1:31 PM UTC
@hkingsbury​ if I use the FeatureReader like you suggested, you have to set the Format to something.  I tried the Schema (Any Format) option but results in this:
Generic Reader: Unable to guess a valid reader name from dataset '<name of SDE connection file>.sde'. A NULL reader will be used instead.
If you set the Format to SDE, then you can only set it to 1 SDE connection file AND you have to set the Feature Types to Read.
Any other ideas?
hkingsbury
  • Apr 23, 2023 8:30 PM UTC
Any other ideas?
You'll still need to set the FeatureReader as SDE, but just enable the read only schema optionimage.png
As I think more about this problem I realise that you can't then use a wild card as a feature type to read in the feature classes.
Attached is an example workspace that firstly uses ArcPy to get all the FCs in the SDE connection, then passes them through to a FeatureReader(SDE) to get the schema. You could also achieve the same with and SQLExecuter, but unsure if you have direct SQL access to the underlying DB
jonvelco
  • Apr 25, 2023 12:39 PM UTC
Thanks for the workbench. This works for 1 SDE connection but I'm trying to run an entire folder of them. The current Connection File user parameter only allows 1 selection - is there a way to use a wildcard like  c:\\temp\\*.sde instead?
gogopotter90
Forum|alt.badge.img+14
  • May 1, 2023 10:39 AM UTC
Hello ,
thanks for ur workspace .
i have used it but I have found that the output of Python caller has not all feature classes .
could I ask if there is a reason for that ? Why did it read most of feature classes but not all of them ?
jonvelco
  • Jan 15, 2025 5:00 PM UTC
​@hkingsbury you wouldn’t happen to still have the workbench you attached back in 2023 would you?  I can’t find it on here anymore...
hkingsbury
  • Jan 15, 2025 7:53 PM UTC
​@jonvelco I don’t sorry! It was likely using the ListFeatureClasses ArcPy function - https://pro.arcgis.com/en/pro-app/latest/arcpy/functions/listfeatureclasses.htm
And then outputting one feature per featureclass and using the featureclass name in a Reader to then read the schema feature.
jonvelco
  • Jan 15, 2025 9:36 PM UTC
​@hkingsbury thanks for the quick response and guidance.  I’ll look into that approach and see what I can come up with.
Is it me, or did all the attachments/files disappear after the forums were updated recently??
vn1
Forum|alt.badge.img+4
  • Jan 16, 2025 2:49 PM UTC
Here’s a screenshot of an example workflow using Directory and File Pathnames and PythonCaller.  Few highlights
  • Directory and File Pathnames filtered to *.sde
  • Python Compatibility set
  • PythonCaller using arcpy.ListFeatureClasses()ArcPY
jonvelco
  • Jan 17, 2025 6:39 PM UTC
I ended up using a Directory and File Pathnames reader pointed at a folder of SDE connections as ​@vn1 suggested.  However, instead of passing the name of the feature classes to a Feature Reader (Format = SDE, Connection = @value(path_windows), Feature types to Read = @value(FEATURECLASS) I just did the work in Python then processed the results.
Open to constructive feedback or tweaks to the Python (see below)
Here’s what the workbench looks like:
Here’s what an example report looks like:
Code for the 3 Python callers is below - let me know if you see any issues!
Feature Classes:
import json  # For dictionary serialization
import fme
import fmeobjects
import arcpy
class FeatureProcessor(object):
def __init__(self):
"""Base constructor for class members."""
pass
def has_support_for(self, support_type: int):
"""This method is called by FME to determine if the PythonCaller supports Bulk mode."""
return support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM
def input(self, feature: fmeobjects.FMEFeature):
# Retrieve the value of the 'path_windows' attribute
path_windows = feature.getAttribute('path_windows')
path_filename = feature.getAttribute('path_filename')
# Retrieve the workspace path from the feature attribute
connFile = feature.getAttribute('path_unix')
arcpy.env.workspace = connFile
# Extract database name, instance, and authentication username from the SDE connection
try:
desc = arcpy.Describe(connFile)
connection_properties = desc.connectionProperties
# Extract the database name, instance, and authentication username from connection properties
database_name = connection_properties.database
instance = connection_properties.instance
auth_username = connection_properties.user
if not database_name:
print(f"Database name not found in connection: {connFile}")
return
if not instance:
print(f"Instance not found in connection: {connFile}")
return
if not auth_username:
print(f"Authentication username not found in connection: {connFile}")
return
except Exception as e:
print(f"Error retrieving connection details from SDE connection: {str(e)}")
return
# Retrieve feature classes from the workspace
featureClasses = arcpy.ListFeatureClasses()
if featureClasses is None:
# If no feature classes are found, print warning or skip processing
print(f"No feature classes found in the workspace: {connFile}")
return # Exit the method to avoid further processing
for fc in featureClasses:
try:
# Describe the feature class
desc = arcpy.Describe(fc)
# Retrieve metadata
geometry_type = desc.shapeType
spatial_ref = desc.spatialReference.name
has_z = desc.hasZ
has_m = desc.hasM
alias = desc.aliasName
# Retrieve field information
fields = arcpy.ListFields(fc)
if fields is None:
print(f"No fields found in feature class: {fc}")
continue
field_info = []
field_info_json = {"fields": []}
for field in fields:
field_details = {
"field_name": field.name,
"field_type": field.type,
"length": field.length,
"precision": None,
"scale": None,
"domain_name": field.domain if field.domain else None,
if field.type in ["Double", "Single", "Integer", "SmallInteger"]:
field_details["precision"] = field.precision
field_details["scale"] = field.scale
field_info.append(
f"{field.name} ({field.type}, Length: {field.length}, "
f"Precision: {field_details['precision']}, Scale: {field_details['scale']})"
field_info_json["fields"].append(field_details)
field_info_str = ";".join(field_info)
# Serialize the field information to JSON
field_info_json_str = json.dumps(field_info_json)
# Get feature count
feature_count = arcpy.GetCount_management(fc)[0]
# Create a new FME feature to output
fcFeature = fmeobjects.FMEFeature()
# Set attributes
fcFeature.setAttribute('FEATURECLASS', fc)
fcFeature.setAttribute('GEOMETRY_TYPE', geometry_type)
fcFeature.setAttribute('SPATIAL_REFERENCE', spatial_ref)
fcFeature.setAttribute('HAS_Z', has_z)
fcFeature.setAttribute('HAS_M', has_m)
fcFeature.setAttribute('ALIAS', alias)
fcFeature.setAttribute('FIELDS', field_info_str)
fcFeature.setAttribute('FEATURE_COUNT', feature_count)
fcFeature.setAttribute('FIELDS_JSON', field_info_json_str)
fcFeature.setAttribute('DATABASE_NAME', database_name)
fcFeature.setAttribute('INSTANCE', instance)
fcFeature.setAttribute('AUTH_USERNAME', auth_username)
fcFeature.setAttribute('path_windows', path_windows)
fcFeature.setAttribute('path_filename', path_filename)
# Output the feature to FME
self.pyoutput(fcFeature)
print(f"Error processing feature class '{fc}': {str(e)}")
continue
def close(self):
"""This method is called once all the FME Features have been processed from input()."""
pass
def process_group(self):
"""This method is called by FME for each group when group processing mode is enabled."""
pass
def reject_feature(self, feature: fmeobjects.FMEFeature, code: str, message: str):
"""This method can be used to output a feature to the <Rejected> port."""
feature.setAttribute("fme_rejection_code", code)
feature.setAttribute("fme_rejection_message", message)
self.pyoutput(feature, output_tag="<Rejected>")
Tables:
import fme
import fmeobjects
import arcpy
def __init__(self):
pass
try:
print(f"Warning: Database name not found in connection: {connFile}")
return # Exit if the database name is not found
if not instance:
print(f"Warning: Instance not found in connection: {connFile}")
return # Exit if the instance is not found
print(f"Warning: Authentication username not found in connection: {connFile}")
return # Exit if the username is not found
print(f"Error: Failed to retrieve connection details from SDE connection: {str(e)}")
return # Exit if an error occurs while describing the connection file
# Retrieve tables from the workspace
tables = arcpy.ListTables()
if not tables:
# If no tables are found, print a warning and skip processing
print(f"Warning: No tables found in the workspace: {connFile}")
for table in tables:
try:
# Describe the table
desc = arcpy.Describe(table)
fields = arcpy.ListFields(table)
if not fields:
print(f"Warning: No fields found in table: {table}")
continue
field_info = []
field_details = {
"precision": None,
"scale": None,
field_info.append(
# Get table row count
row_count = arcpy.GetCount_management(table)[0]
tableFeature = fmeobjects.FMEFeature()
# Set attributes
tableFeature.setAttribute('TABLE_NAME', table)
tableFeature.setAttribute('ALIAS', alias)
tableFeature.setAttribute('FIELDS', field_info_str)
tableFeature.setAttribute('ROW_COUNT', row_count)
tableFeature.setAttribute('FIELDS_JSON', field_info_json_str)
tableFeature.setAttribute('DATABASE_NAME', database_name)
tableFeature.setAttribute('INSTANCE', instance)
tableFeature.setAttribute('AUTH_USERNAME', auth_username)
tableFeature.setAttribute('path_windows', path_windows)
tableFeature.setAttribute('path_filename', path_filename)
self.pyoutput(tableFeature)
print(f"Error: Failed to process table '{table}': {str(e)}")
continue
def close(self):
pass
pass
Domains:
import fme
import fmeobjects
import arcpy
def __init__(self):
pass
# Retrieve the workspace path and 'path_windows' attribute from the input feature
try:
return
if not instance:
return
return
return
# Retrieve all domains in the workspace
domains = arcpy.da.ListDomains(arcpy.env.workspace)
# Check if any domains were found
if not domains:
print(f"No domains were found in the workspace: {connFile}")
return
for domain in domains:
domain_name = domain.name
domain_type = domain.domainType
description = domain.description
if domain_type == "CodedValue":
# Process coded value domains
for code, value in domain.codedValues.items():
# Output a feature for each code-value pair
outputFeature = fmeobjects.FMEFeature()
outputFeature.setAttribute("DOMAIN_NAME", domain_name)
outputFeature.setAttribute("DOMAIN_TYPE", domain_type)
outputFeature.setAttribute("CODE", code)
outputFeature.setAttribute("VALUE", value)
outputFeature.setAttribute("DESCRIPTION", description)
outputFeature.setAttribute("DATABASE_NAME", database_name)
outputFeature.setAttribute("INSTANCE", instance)
outputFeature.setAttribute("AUTH_USERNAME", auth_username)
outputFeature.setAttribute("path_windows", path_windows)
outputFeature.setAttribute("path_filename", path_filename)
self.pyoutput(outputFeature)
elif domain_type == "Range":
# Process range domains
min_val, max_val = domain.range
# Output a single feature for the range domain
outputFeature.setAttribute("MIN_VALUE", min_val)
outputFeature.setAttribute("MAX_VALUE", max_val)
else:
# Process unknown domain types
outputFeature.setAttribute("DESCRIPTION", "Unknown domain type")
def close(self):
pass
pass
