Read a single file from a zip file
  • June 14, 2023
  • 217 views
gboquin
I have a zip file that has a csv file and multiple jpgs. I tried a CSV feature reader-- not a CSV reader-- as I was trying to read the file with in the zip file but that didn't work. I am using FME 2022.2.2. Is there a way to only extract a particular file from the zipfile? I dont want to unzip the entire thing as it will take a long time.
Thanks in advanced.
virtualcitymatt
Forum|alt.badge.img+47
You should be able to read the csv by just appending the path to the csv after the zip path. Something like this:
path/to/zipfile.zip/path/to/csvfile.csv
Have you tried that?
Heres the doc: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop/Workbench/archive_files_reading.htm
gboquin
  • June 15, 2023
Thanks for your reply @virtualcitymatt​. That was what I thought but I am guessing that this might be a bug on the feature reader. Let me clarify, I could read the file but I was in some sort of binary format and didnt recognize the file schema or data and caused my workbench to run for more than 30 mins when it should have taken 3-4 tops.
I was able to modify the python caller on the zip extractor to only extract the csv file. It took some digging around on the python libraries to figure this out particularly since I dont know python.
