Question relates to geodatabase
  • Jun 8, 2023 11:02 AM UTC
  • 76 views
spiderman
Forum|alt.badge.img+7
Hello ,
i have geodatabase data as input ,it includes different points ,lines ,annotations .
I would like to read this data in FME workbench and filter specific data from them for city then write the output again into new geodatabase writer .
my problem :
when I use spatial filter and use the specific city as filter and the geodatabase data as candidate .
so the passed port include all data together and for sure not each input has the same attribute names as other .
How could I write the output for my data (passed port ) into geodatabase format and each writer includes only his own data without any problem .
Best answer by caracadrian
Thanks for ur reply , I understood that ,all data merged together and become one .
I am looking if there is easy way to seperate them Bcs I have not only 3 readers .
i have around 70 readers ,I do not want to use 70 spatial filter .
But if not ,so I will use many spatial filter
Use a fanout by fme_feature_type on the writer.
I think you also have to expose some other attributes but it should work.
For simplicity use Paralel filters for different geometrie types.
caracadrian
Forum|alt.badge.img+23
  • Jun 8, 2023 3:48 PM UTC
You can either use 3 paralel SpatialFilters or separate the data back after filtering.
Once you joined more data streams they become one. That's why all your data together after filtering.
spiderman
  • Jun 8, 2023 4:20 PM UTC
caracadrian
  • Jun 8, 2023 4:44 PM UTC
