PythonFactory failed to load python symbol `FeatureProcessor'
  • May 18, 2021 10:08 AM UTC
  • 6 replies
  • 765 views
Greetings,
I have selected the Esri ArcGIS Python 3.7 option, in Translation.
I am getting a Python symbol error??
Any ideas how to resolve this issue??
The error msg is:
Factory proxy not initialized
PythonCaller_2 (PythonFactory): PythonFactory failed to process feature
PythonCaller_2 (PythonFactory): A fatal error has occurred.
Regards,
Clive
  • May 18, 2021 10:14 AM UTC
Check that the Python code in your PythonCaller or PythonCreator has either a function or a class with the name "FeatureProcessor" (case sensitive).
  • May 18, 2021 1:13 PM UTC
Hi David,
This code used to work, it is suddenly throwing an error.
Regards,
Clive
import fme
 import fmeobjects
 import requests
 def processFeature(feature):
   resp = requests.post(FME_MacroValues['PortalURL']+"/Portal/sharing/rest/generateToken?f=pjson&client=referer&expiration=60", data={"username":FME_MacroValues['UserName'], "password":FME_MacroValues['password'], "referer":FME_MacroValues['PortalURL']+"/server/rest"})
   feature.setAttribute("response", str(resp.json()))
  • May 18, 2021 1:20 PM UTC
I finally figured out what was throwing the error.
The class to process, had a type...
😨 Seriously
  • May 18, 2021 2:08 PM UTC
😨 Seriously
That's the most common reason for this error message, indeed :-)
harmen
Forum|alt.badge.img+10
  • Nov 24, 2022 9:32 AM UTC
😨 Seriously
@clives-bmh​ : I'm pretty new to Python and got the same error.
Can you explain / show what you mean with "The class to process, had a type' ?
Thanks!
(maybe @david_r​ , you can explain it?)
  • Nov 24, 2022 9:42 AM UTC
Thanks!
Can you please post a screenshot of the PythonCaller configuration.
