PythonCaller list to feature
  • September 4, 2023
  • 125 views
nielsgerrits
Forum|alt.badge.img+64
To get the number of features from a FeatureClass in a File Geodatabase you can use arcpy's GetCount.
arcpy.management.GetCount(<featureclasspath>)
So I tried and got this working.
import fme
import fmeobjects
import arcpy
class FeatureProcessor(object):
    def __init__(self):
        pass
    def input(self, feature):
        arcpy.env.workspace = feature.getAttribute('path_windows')
        feature_classes = arcpy.ListFeatureClasses()
        fc_list = []
        for fc in feature_classes:
            count = arcpy.GetCount_management(fc)
            fc_list.append((fc, int(count[0])))
            print(fc_list)
        self.pyoutput(feature)
    def close(self):
        pass
    def process_group(self):
        pass
But no matter what I tried, I could not get the list to the feature. I expected it to be something like:
feature.setAttribute("fc_list",fc_list)
The log keeps reporting the error:
Python Exception <TypeError>: Could not convert attribute value to a supported attribute type.
After a while I surrendered and a colleague saved me with the following solution:
import fme
import fmeobjects
import arcpy
    def __init__(self):
        pass
        record_counts = []
        count = 0
            featurecount = arcpy.GetCount_management(fc)[0]
            feature.setAttribute("record_counts" + "{" + str(count) + "}.FeatureClass",fc)
            feature.setAttribute("record_counts" + "{" + str(count) + "}.FeatureCount",featurecount)
            count = count + 1
    def close(self):
        pass
        pass
It does work, but it feels hacky. So my question is, is this the way it should be done? I'm trying to learn the right thing here. Thanks for looking.
Best answer by kailinatsafe
Hello @nielsgerrits​! I think you're on the right track, if not very close. It looks like you're trying to save a list of tuples to a single attribute, perhaps we should be trying to store them as separate lists/attributes? Take a look at the following script snippet:
count_list = []
    count_list.append(count[0])
feature.setAttribute("record_counts{}.FeatureClass", feature_classes)
feature.setAttribute("record_counts{}.FeatureCount", count_list)
I don't think we have this documented anywhere in the Getting and setting attributes doc, I will see if it can be added! Hope this helps, Kailin.
kailinatsafe
Forum|alt.badge.img+23
  • September 6, 2023
count_list = []
nielsgerrits
  • September 8, 2023
count_list = []
Hej @kailinatsafe, thanks for the response. This really helps, adding it to the documentation would be great :)
