Python Exception <TypeError>: bufsize must be an integer
  • Aug 23, 2022 6:27 AM UTC
  • 750 views
rejith3119
I was trying to use below python code in FME. But it is throwing an error i.e. '<TypeError>: bufsize must be an integer'. Can anyone help me on this to get it resolved? I will provide the complete script on request if required.
Thanks in advance
#Code used in python caller
arg1 = ['pg_dump', '-t', 'schema1_table1', 'server1_conn','|','psql', 'local_conn']
proc = subprocess.Popen(arg1,cwd=directory, shell=True,stdin=PIPE)
#where
#server1_conn = "host=<server_host> port=<server_port> dbname=<server_db> user=<server_user> password=<server_pwd>"
#directory = C:\Program Files\PostgreSQL\14\bin
Best answer by rejith3119
I'm suspecting you cannot pipe ("|") the output the way you're doing, you probably need to specify the stdout parameter to subprocess.Popen() instead, and take it from there.
Hi @david_r​ ,
There is no issue with the pipe("|") character. Actually the error was with the variable declaration and some syntax in the argument value e.g. 'server1_conn'. After correcting it the python caller is working fine. I have used this 'subprocess.popen' method to get control on the child process like below. Your comment helped me to explore more on subprocess.Popen() documentation. Thank you for the support
proc = subprocess.Popen(...)
try:
    outs, errs = proc.communicate(timeout=15)
except TimeoutExpired:
    proc.kill()
    outs, errs = proc.communicate()
  • Aug 23, 2022 5:13 PM UTC
rejith3119
  • Aug 24, 2022 2:17 PM UTC
Hi @david_r​ ,
try:
    proc.kill()
  • Aug 29, 2022 7:55 AM UTC
Hi @david_r​ ,
try:
    proc.kill()
That is great to hear, thank you for sharing your findings!
