Python Exception
  • Mar 22, 2023 5:43 PM UTC
  • 5 replies
  • 163 views
We used to have the following 'Emailer' Transformer in our FME Desktop /Server 2021.2.2 and it worked fine:image
However after upgraded to 2022.2.3, we experienced the following Python Exception error for Emailer:
imageAny idea how to fix that? Thanks.
Best answer by nielsgerrits
Hi @nielsgerrits​
Just to confirm, do you mean to first uninstall 'Emailer' Transformer from my FME Desktop (right click on Emailer in Transformer Gallery and Delete)?
Then Download the following latest Emailer from Hub?
imageThen save the above downloaded emailer in the default Transformer folder for Workbench to use?
Sorry still relatively new to the process. Thanks.
Probably multiple ways to do this, but onder tools, options is a menu with packages, you can uninstall those there. Then simply enter emailer in the canvas, select it and it will reinstall.
On a second thought, what is the selected python version? See the navigator, under scripting.
nielsgerrits
Forum|alt.badge.img+67
It is an FME HUB transformer now, can you try to uninstall and reinstall it?
  • Mar 22, 2023 6:00 PM UTC
Hi @nielsgerrits​
nielsgerrits
  • Mar 22, 2023 6:14 PM UTC
Hi @nielsgerrits​
  • Mar 22, 2023 6:46 PM UTC
Great advice! Ran the following updates and the error gone away:
However, still no e-mail received. Reviewed the workspace closely and noticed there was no activities after the indicated '?' part?imageIt worked before the upgrade. Under 'ChangeDetector', should I change from the connected 'Inserted' to 'Unchanged' for that 18 rows of data that we need?
  • Mar 22, 2023 7:13 PM UTC
By changing the connector to 'unchanged' seems to fix it.
Thank you for your help @nielsgerrits​ !
