PostGis Writer error
  • Jan 13, 2021 7:05 PM UTC
  • 77 views
Hello I'm running a workspace but this error is shown when it tries to write a table in PostGis:
"Bulk copy failed on table 'nld.src_bag_q121' using delimiter ";". Error was 'server closed the connection unexpectedly. This probably mean the server terminated abnormally before of while processing the request.'
A fatal error has ocurred. Check the logfile above for details.
Do you know how to resolve this error? Thanks in advanced.error_postgis
joeri
  • Jan 14, 2021 8:47 AM UTC
I used to have this quite a lot when I was writing to an Azure database, however this improved dramatically when I changed from wi-fi to the use of an ethernet cable.
