Placement of clipped rasters in PDF aren't consistent.
  • Sep 30, 2022 2:09 PM UTC
  • 90 views
I'm buffering a points shapefile, then using the resulting square polygons to clip a raster (vrt OS backdrop). The clipped rasters are then passed to a PDF PageFormatter to produce location maps for each point. My problem is the raster outputs once written to PDF seem to move - placed in relation to the location of the point. how can I force the rasters to be drawn in the same place on the page everytime?
debbiatsafe
Forum|alt.badge.img+24
Hello @cbrown​
Are you able to share an example of the behaviour you're describing? If you can share the workspace, that would also be helpful.
The PDFPageFormatter should set the pdf_frame_rectangle format attribute, which controls the position of a given frame on the PDF page. In contrast, the pdf_world_rectangle controls the extents of the features (the point and raster background in your case) displayed in a PDF frame.
  • Oct 4, 2022 10:08 AM UTC
Hi @debbiatsafe​
thanks for getting back to me. I've set the position in the PDFPageFormatter. Does this automatically set the pdf_frame_rectangle format attribute when transferred to the PDF Writer? Or do I need to enable this (and maybe other attributes)? I've attached an example where you can see the map content shifts from page to page.
debbiatsafe
Hi @debbiatsafe​
Using the PDFPageFormatter should set the pdf_frame_rectangle format on output features. I suspect the behaviour you're seeing is caused by the fact you are using one PDFPageFormatter and then manually changing pdf_page_number afterwards.
The cumulative bounding box/extents of all features for each frame/box defined in the PDFPageFormatter is used to determine the pdf_world_rectangle. Since you have multiple locations for a single frame, the pdf_world_rectangle extents encompasses all features and causes the shifting behaviour.
I would recommend using a BoundsExtractor on the background map features and using those values to set pdf_world_rectangle in the format <lowerLeftX> <lowerLeftY> <upperRightX> <upperRightY>. Also set a unique frame name for each map frame for each page--the name can be any format.
I'll note also it may be easier to use one frame/box per map instead of defining one for the point features and one for the background as your screenshot shows. This ensures each frame has consistent values.
I have attached an example demonstrating this approach and I hope it helps.
Forum|alt.badge.img+63
Alternatively, get the bounds using a BoundsExtractor and offset everything to -1*xmin, -1*ymin, this has the effect of moving all objects so that their lower left bounding box corner lands at 0,0
