Passing an array object as HTTPCaller query string
  • Mar 23, 2023 3:29 PM UTC
  • 299 views
I am trying to access a JSON API by using a HTTPCaller and I am struggling with passing an array object as a Query String Parameter. The documentation for the 'extra' key I am trying to access looks like this.
Request Query parametersThe code sample they give where you can see the 'extra' parameter as an array is here:
"key": "xxxxx-xxxxx-xxxxx-xxxxx",
"query": "High Street",
"country": "gbr",
"id": "town=Maidenhead",
"extra": {
"exclude_areas": [
"gbr_channel_islands",
"gbr_northern_ireland",
"usa_non_contiguous"
"exclude_pobox": true,
"best_match_only": true,
"no_groupings": true
How do I go about adding the extra array as a query string parameter when the API is expecting to be given an array?
many thanks in advance
  • Mar 23, 2023 3:55 PM UTC
You'll have to URL encode the JSON document before the HTTPCaller using the TextEncoder, e.g.:
  • Mar 23, 2023 4:20 PM UTC
Thanks David - I am missing a step I think.
if I pass the text I think I need to the Textencoder ie
the encoded output is %7B%0A%09%22best_match_only%22%3A%20true%2C%0A%7 which the HTTPCaller still interprets as a string - what have a missed?
  • Mar 23, 2023 4:23 PM UTC
That is correct. Query parameters are always sent as strings, although the server may interpret it as something else once the string data arrives.
  • Mar 23, 2023 4:55 PM UTC
I think it might be an issue I can't overcome, as the API always seems to interpret what it is passed as a string. Thank you for your help though
