OVF file format, writer and reader
  • Mar 31, 2022 4:00 PM UTC
  • 73 views
boubcher
Forum|alt.badge.img+11
Is there a way to read and write the .ovf file format of orbit
https://kb.orbitgt.com/209/technology/supported_formats/vector/ovf
Thanks
jovitaatsafe
Hi @boubcher​,
It doesn't look like we have support for this format just yet. You might be interested in upvoting this idea to add support for reading .ovf files and consider adding your use case or why you might want to be able to read orbit files in FME for your workflows. This helps inform our product development team so it'd be great to hear from you on that!
In the meantime, are you able to workaround it using one of Orbit's export file formats that FME does support such as SHP, KML, or other?
