Output Josn attribute values showing more precision values ? even passed rounding of 2!
  • Oct 25, 2021 5:54 AM UTC
  • 5 replies
  • 150 views
I am converting ESRI gdb tables to Josn format(text_line), but unfortunately few of attribute values are given extra/unnecessary precision?
data from tables : "aos" : 105.20 ,"aos" : 293.22
output generated : "aos" : 105.20999999999999, "aos" : 293.22000000000003
To avoid this I have used attribute rounder , but no use, client required only 2 digits after (it should be float) . could some one help to resolve this issue on this.
I have used the below transformers
  1. gdb reader
  2. attribute manager and attribute rounder
  3. Josn templater
  4. Text file writer (text_line)
Thanks in advance
Chandra Sekhar Guda
Best answer by david_r
If you want to keep "aos" as a proper floating point value in the JSON, try using fn:round() in the expression of the JSONTemplater, e.g.
"aos": fn:round(fme:get-attribute("my_aos_attribute"), 2)
This will round "my_aos_attribute" to the nearest 2 decimal places and output it as "aos".
Forum|alt.badge.img+63
Since you're going to text, the StringFormatter is probably the best way to go, using .2f as the format string should do the trick.
  • Oct 25, 2021 7:48 AM UTC
  • Oct 25, 2021 8:44 AM UTC
Thank you very much David_r, it worked, great
jelle
Forum|alt.badge.img+23
  • Feb 10, 2022 3:34 PM UTC
thanks, @david_r​
You saved my day!
chazbacca
Forum|alt.badge.img+7
  • Nov 30, 2023 2:27 AM UTC
gold! thank you for the question and answer!
