OSG Reader: Ignoring unsupported node + OSG Reader: Ignoring unsupported geometry - only surfaces are supported
  • Nov 30, 2021 11:30 PM UTC
  • 91 views
I would like to use FME as a 3d model converter/processor. We know that the 3D Clipper of FME is not being supported yet and I would like to split the osgb model with z values using https://www.openscenegraph.com/ such as using this example code https://github.com/openscenegraph/OpenSceneGraph/blob/master/examples/osgclip/osgclip.cpp#L109 . However, I find that the osgt file cannot be recognized by FME and the following error messages are shown:
How I can generate a cropped 3d model that can be opened by FME? Any suggestions are welcome! Thank you.
kailinatsafe
Forum|alt.badge.img+24
Hello @nickshek​ , would you be willing to share more information on whats going on? If you could supply any of the following, this would be great:
  • A full logfile?
  • Screenshot of your reader parameters?
  • Sample data?
  • What version/build of FME Workbench you're currently using?
Also, is any geometry being read in at all? If you haven't taken a look at the OSG Reader documentation, it may be worth checking out, as it lists whats supported in FME. Best, Kailin
  • Dec 30, 2021 3:31 AM UTC
  • A full logfile?
  • Sample data?
I am using openscenegraph 3.6.5 with the following sample commands:
osgconv Tile_+5568_+5452.osgb Tile_+5568_+5452.osgt
 Tile_+5568_+5452.osgb can be loaded into the FME 2021
But Tile_+5568_+5452.osgt can be loaded into FME 2021 with the following error messages:
 Worker 25504 > OSG Reader: Ignoring unsupported geometry - only surfaces are supported
How can I send the sample data to you privately ? Thank you so much
