Objects in this class cannot be updated outside an edit session (ArcGis SDE)
  • Oct 22, 2020 6:58 AM UTC
  • 1424 views
fme_hans
With FME I want to update one column of an ArcGis sde data table. The table is a non versioned feature class with enable archiving and an active service has been created.
I get the following error:
I have tried all the different transaction types of the writer but it makes no difference.
What could it be?
Greatngs, Hans
Best answer by oscard
Does the user you are using to update the feature class have edit capabilities?
oscard
Forum|alt.badge.img+23
  • Oct 22, 2020 7:06 AM UTC
fme_hans
  • Oct 22, 2020 7:25 AM UTC
Yes i have edit capabilities.
fme_hans
  • Oct 22, 2020 7:56 AM UTC
Oscard, you are right. I changed to an other user and now i can write.
Thanks, it is solved
oscard
  • Oct 22, 2020 7:58 AM UTC
I'm glad it's working for you now! :)
