Normalizing greyscale images
  • Jan 19, 2021 9:28 PM UTC
  • 137 views
lianaolianov
Forum|alt.badge.img+5
Can anyone please help me on how to normalize a set of greyscale images using FME ? (Transforming the scale range of radiometric values to the [0,1] interval)
thank you very much
Best answer by tomf
To normalise into [0,1] you can use the expression:
( x - x_min ) / (x_range)
so for your case:
  1. A RasterStatisticsCalculator to calculate min and range on Band 0
  2. Followed by a RasterExpressionEvaluator for one band, and use the expression:
(A[0]-@Value(A:band0.min))/@Value(A:band0.range)
This output from that is now normalised [0,1]
tomf
Forum|alt.badge.img+31
  • Jan 19, 2021 11:04 PM UTC
so for your case:
tomf
  • Jan 20, 2021 10:35 PM UTC
so for your case:
In detail:
Set the RasterStatisticsCalculator:
RSC_normalisingThen open the the Arithmetic Editor in the RasterExpresionEvaluator from the drop down menu on the right of the Expression column:
REE-normalisngAnd finally create the expression for raster A band 0 (single raster, greyscale):REEeditor_normalising
