Neighbour Finder Query
  • October 28, 2021
  • 35 views
ingalla
Forum|alt.badge.img+10
I have been using the neighbour finder to create a line between an existing point and road line, which works fine up to a point. I am sure the below is fairly straightforward but have been racking my brains to no avail. I have tried the group by which is giving some strange results too...
Both the Road and Point Datasets have a RoadID attribute meaning that all points should be linked to the correct road, this is not currently happening with some points being linked the shortest distance to the nearest road and not to the correct road.
imageAny suggestions how i can get the points to link to the correct road via the RoadID field?
The image below shows the results i am getting with the Yellow lines drawn on where the links should be going.
Thanks in advance...
Best answer by virtualcitymatt
You need to use the Group Processing option - group by the ID. It's the top checkbox which is off by default
virtualcitymatt
Forum|alt.badge.img+47
  • October 28, 2021
mark2atsafe
Forum|alt.badge.img+59
  • October 28, 2021
If you don't have an ID that matches the point to the road segment (yes, use the Group By) then it looks like you have the numbers in the building properly rotated and can use them to orient the line direction.
So, in the abstract, expose the rotation of the number text, copy it to the building (PointOnAreaOverlayer) then from there to the actual point (again PointOnAreaOverlayer).
Then use the NeighborFinder and create a list of the results. You can then check if the rotation of the text is approximately aligned to the bearing of each nearest road feature. If it is within (say) 15 degrees, then you've got the correct road.
ingalla
  • October 28, 2021
Thanks for your reply, all sorted. The initial data was a bit suspect, now it has been modified all works as expected...thanks again...
