Multiple points in one area to create as many areas as points
  • Aug 4, 2020 11:53 AM UTC
  • 121 views
Hi everyone!
I'm trying to make a PointOnAreaOverlay crossing a points database with a polygons database. The problem is that more than one point it's inside of a some polygons, and I wanna create one polygon for each point... even it that create duplicate polygons.
When I use the tool PointOnAreaOverlay, it's creating just one polygon and taking the data from the first point. How can I create a separate polygon for each point?
Thank you very much!!!
Best answer by redgeographics
You can let the PointOnAreaOverlayer create a list on the polygons, if you then use a ListExploder it will create one copy of the original polygon for every point that's inside it.
Forum|alt.badge.img+63
You're a genious!! It works perfectly!
  • Aug 4, 2020 5:12 PM UTC
For polygons with multiple points you can do a voronoi diagramm of these points and clip the result on the original polygon
