Merging 5 different postgis db to new postgis db
  • January 6, 2021
  • 14 views
I have 5 postgis db with same schema and having same layer names. I want to merge all these five db into new db in new projection. I am trying to do it with by adding reader into single merge feature and adding reprojector and output to writer postgis new db.
I am getting the error :Fanout feature type public.roads failed to find feature type template public.roads.
How to do this? Any clue. I am using FME 2020.2​
If it's a one time deal, use the 'Generate Workspace' function (CTRL-G) to configure the 1st one. Run it, then change the connection parameter in the navigator to the next one until you finish.
It will give you a lot more control over the counts of records and whatnot as well to ensure data integrity.
