Merge records into one row
  • Aug 29, 2023 1:43 PM UTC
  • 87 views
Greetings,
I used FeatureJoiner to merge a Spatial and non-spatial records using a common value (grid_id).
I use a Tester to select a scenario ie date is 2000, 2030, 2040, etc.
I then use a StringConcaternator to add a value to a cell (overwrite cell value), the cell for 2000 will be 0 -5.
I also have a Tester for 2030 (2C), 2030 (4C), 2040 (2C), 2040 (4C), etc.
The records in the FeatureHolder, should all be written to a single row.
Instead I have a row per date/scenario??
For 2000 I have the following data.
The output is written over n rows, not a single row??
How do I append records into a single row??
Any suggestions are appreciated.
Thanks
Clive
Forum|alt.badge.img+54
  • Aug 29, 2023 2:31 PM UTC
To get from your last image to a single row, use an Aggregator with a group by on your grid_id, set Accumulation Mode - merge incoming attributes
Thanks forgot about the Aggregator, that concatenated the records into a single row.
