Dear FME community.
I try to merge multiple lines attributes for use an Emailer at the end (like an object) like that :
I tried aggregator, HTMLextractor, AttributeCreator but the result is not good.
Have you got any idea ?
Thanks.
Dear FME community.
Thanks.
Best answer by erik_jan
Using the AttributeCreator, creating Field1 should work if you use the Text Editor option.
