Merge multiple lines values into one
  • Jan 2, 2020 6:01 PM UTC
  • 174 views
geo-x
Dear FME community.
I try to merge multiple lines attributes for use an Emailer at the end (like an object) like that :
I tried aggregator, HTMLextractor, AttributeCreator but the result is not good.
Have you got any idea ?
Thanks.
Best answer by erik_jan
Using the AttributeCreator, creating Field1 should work if you use the Text Editor option.
erik_jan
Forum|alt.badge.img+26
  • Jan 2, 2020 6:06 PM UTC
erik_jan
  • Jan 2, 2020 6:23 PM UTC
This would merge the fields 1 - 3 into Field 1.
To merge multiple lines with Field 1, you can use the Aggregator transformer, using the option to merge the Field 1 attributes, using the New Line as separator.
@lalandexavier The HTMLReportGenerator has a Table option (at the bottom of the list of Page Contents) that will create an HTML table, and perhaps you can add that HTML to your email.
geo-x
  • Jan 3, 2020 9:46 PM UTC
Thank you very much ! I tried it today and that works very well, nice job !
