Marking FME server job failed
  • Aug 20, 2023 10:24 AM UTC
  • 130 views
naveen
Forum|alt.badge.img+7
When the published workspace is unable to connect to database or ArcGIS services via feature reader, then the translation fails but the FME server job status is success. I would like to know if there is a way that FME server status can be marked as failure when specific condition are not met with in the FME workbench workflow??
Forum|alt.badge.img+63
One thing you can try is connecting a Terminator to the <Rejected> output of the FeatureReader to force a job termination.
keziaatsafe
Forum|alt.badge.img+8
Hi @naveen​ ,
In addition to redgeographics' suggestion, I would also recommend confirming that the Rejected Feature Handling parameter in FME Workbench is set to Terminate Translation instead of Continue Translation. This parameter is located in the Navigator panel > Workspace Parameters > Translation > Rejected Feature Handling.
Hope this helps!
Kezia
naveen
  • Aug 25, 2023 4:31 AM UTC
Thanks Guys..will use it and get back.
