Looking to extract 12 different unique number values in a CSV file. What would be the ideal way to accomplish this task. TIA
  • Jan 24, 2023 8:05 PM UTC
  • 68 views
dustin
Forum|alt.badge.img+36
  • Jan 24, 2023 9:04 PM UTC
If it's only 12 I would probably type them manually into a TestFilter or AttributeFilter. If you are using a recent version of FME, you can run the workspace with Feature Caching turned on, and then import values from the feature cache in the AttributeFilter.
  • Jan 26, 2023 7:31 PM UTC
Thanks ddbrocato for the suggestion. Worked great!
