log file text line data -- Separate columns
  • Feb 20, 2023 11:06 AM UTC
  • 58 views
asadamjad
Participant
Forum|alt.badge.img+12
how can I separate the data into separate columns?
E.g
Date                         Information           result
2023-02-20 07:24:00         inform             Current FME version: FME 2022.2.0.0 (2022110)
ctredinnick
Forum|alt.badge.img+22
  • Feb 20, 2023 11:17 AM UTC
CSV represents any text file structure where columns are separated by a delimiter, usually a comma. The delimiter can be anything you like, not just a comma. Read the log file with a csv reader, I'm sure you can figure it out from there, and all you need to do is set the schema.
arnovananrooij
Forum|alt.badge.img+5
You can use the CSV reader with a pipe (|) as the delimiter
asadamjad
Participant
  • Participant
  • Feb 20, 2023 2:39 PM UTC
Thanks for the reply, @ctredinnick​
I'm stuck on one more thing; how can I separate them now?
arnovananrooij
This is not a fme log file...​
