List all Shapefiles in a Folder?
  • Mar 27, 2023 11:46 PM UTC
  • 172 views
vxn43
Forum|alt.badge.img+20
I have hundreds of shapefiles in different folders and subfolders. I would like to create an excel file that shows three columns:
Col1 = Name of .shp file
Col2 = Geometry of .shp file
Col3 = Directory/Path of .shp file
For Transformers, I think I need to start with Creator - FeatureReader, then I get stuck.
Best answer by david_r
Since you need the geometry type, I'd use a second FeatureReader after the Path reader (set to search for *.shp recursively) , configured like this:image You'll find the geometry type in the attribute "fme_geometry{0}".
tomfriedl
Forum|alt.badge.img+14
  • Mar 28, 2023 3:41 AM UTC
  • Mar 28, 2023 6:42 AM UTC
vxn43
  • Mar 28, 2023 4:42 PM UTC
Thank you both for pointing me in the right direction.
