KMZ to JSON
  • August 12, 2022
  • 87 views
slade_bridges
i have seen a lot of write ups with this heading but none actually do what the title says. i have been able to read a kmz and get it to a writer but the .json file is empty. there is no error message, just no data when i inspect the json. i have attached the workbench. i want the user to select a kmz and the workbench write it as a json, i am using ESRI JSON because the GeoJSON will error out.
muzhnasto
Forum|alt.badge.img+12
  • August 15, 2022
Hi @slade_bridges​ , look at my version, maybe it will help you )
kmz
