Keep only part of string matching Regex
  • Feb 17, 2021 7:24 PM UTC
  • 2601 views
lambertus
Forum|alt.badge.img+25
A dataset of 900 records contains a string attribute. This string varies in length and contains always a X- and Y-coordinate.
Example:
":5.781699137962022,"rijksdriehoekX":181934.095,"rijksdriehoekY":474580.092,"rijksdriehoekZ":0
I just want to get the part in bold and created a Regex to select this part. My idea is to replace the complete string and just keep the string part with the coordinates (bold part).
My Regex: rijksdriehoekX":[0-9]{6}.[0-9]{3},"rijksdriehoekY":[0-9]{6}.[0-9]{3}
Any ideas how to solve this issue?
Best answer by hkingsbury
Thanks @hkingsbury​ ! The regex works perfect. I have filtered now all records which contain coordinate values.
However, I still need to subtract these coordinates from the string per record and turn them into attribute values in such a way they can be used in a VertexCreator. Do you have any suggestions? 😃
My goal, using the example above, get finally 2 columns with x and y coordinates.
2021-02-17 21_57_45-Clipboard
A small change to the regex can achieve that, adding two extra capture groups around the coords
(rijksdriehoekX":(\d{6}\.\d{3}),"rijksdriehoekY":(\d{6}\.\d{3}))
make sure you set the subexpression list name under advanced in the stringsearcher
Screenshot 2021-02-18 100358
hkingsbury
Forum|alt.badge.img+73
  • Feb 17, 2021 7:39 PM UTC
You're really close. I've made a couple of minor changes to your regex
(rijksdriehoekX":\d{6}\.\d{3},"rijksdriehoekY":\d{6}\.\d{3})
  1. adding a capture group around the whole statement "(...)"
  2. switch [0-9] to \d
  3. escaped '.'. In regex a '.' means any character. by escaping it with a '\' you will only match a '.'
to extract that match, use a StringSearcher. It there is a match it will come out on the '_first_match' attribute
One thing I did note, are your coordinates always going to be 6 long followed by 3dp? you may want to look at adding a range, especaily for the decimal places. {1,3} will match 1 to 3 numbers long
lambertus
  • Feb 17, 2021 8:51 PM UTC
hkingsbury
  • Feb 17, 2021 9:05 PM UTC
lambertus
  • Feb 18, 2021 8:40 AM UTC
Thanks @hkingsbury​ ! Works perfect 😃
