Join and sum points onto polygon grid cells based on attributes in points layer
  • Dec 12, 2022 3:21 PM UTC
  • 216 views
albjoh
Forum|alt.badge.img+5
I have adress points representing persons and attributes for each point including a categorization into age intervals. I also have a polygon grid to which I want to sum up all persons in each age interval to each grid cell. My output should be the grid polygons with a sum for each age interval, like this:
"grid ID" "age 0_5" "age_6-17"
1 12 56
2 23 109
3 4 13
I've tried several solutions eg. with "point on area overlayer" combined with the "list summer" but havn't been able to make it work. I use the 'generate list on an ouput area' option but my resulting "sum_" from list summer returns only "0" for all rows. Do I miss something with the lists buidling? Or any other ideas how this can be done?
Thanks
Best answer by albjoh
Solved it. Before the pointOnAreaoverlayer I used an attributecreator for setting up the attribute fieldnames (the age intervalls). Then finished off with aggregator grouped on both Id and an attribute for age intervall. Attributes to sum was set to the overlaps col from pointOnAreaoverlayer.
@albjoh​ I would try PointOnAreaOverlayer to associate the grid cell to the address only, then use Aggregator - group by the cell id and aggregator has sum options. Or you could also use StatisticsCalculator and also Group By the grid ID.
albjoh
  • Dec 13, 2022 6:39 AM UTC
Thanks @markatsafe (Safer)​ Tried this and it results in a nice total sum of points per grid cell.
However it will not take care of the grouping of sums for the age intervals. I have tried setting a Testfilter after the PointOnAreaOverlayer and then Aggregators for each filtered stream (4 age intervals in total) which gives me the sums for each interval. However then I want them all back in one final output dataset showing for each gridcell, the sum of people in each age intervall.
Tried merging/joining them all together which only partially works since the fields ("age_0_5", ""age_6_17" etc) do get merged but only contents from one field at the time... At most times there are multiple points in one grid cell and those belong to different age intervals. Any Ideas ?
albjoh
  • Dec 13, 2022 3:22 PM UTC
