Is there way to generate X & Y Fields from Lat Long in FME?
  • Jul 8, 2021 9:06 PM UTC
  • 130 views
Hi all,
I have two fields Lat and Long which are my geometry fields.
From this is there a way to have two more fields that can show X & Y using this information in same table?
Reason is when i publish lat and long to my arcgis map it seems to move by 5-10m from the actual point.
hkingsbury
Forum|alt.badge.img+73
  • Jul 8, 2021 9:46 PM UTC
You can use the attribute reprojector to create two new fields for your X/Y Coord pairs
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/attributereprojector.htm
