Is there any way to use FME Desktop to square (true) polygon corners to 45 or 90 degrees?
  • Nov 14, 2021 4:46 PM UTC
  • 327 views
lance
Forum|alt.badge.img+5
I have about 500,000 building footprints that are collected to varying degrees of accuracy. I would like to true these footprints so the corners are either 45 or 90 degrees on the polygons as depicted below. Is there a means to do this using FME desktop? The corners are typically within +/- 5 to 10 ground units of being true.
Before:
BeforeAfter:After
aron
Forum|alt.badge.img+16
  • Dec 21, 2021 9:24 AM UTC
I was wondering this as well. Does anyone know how it is done?
geomancer
Forum|alt.badge.img+71
  • Dec 21, 2021 2:35 PM UTC
Maybe something like this:
  1. Create the 2D Oriented Bounding Box of the feature (BoundingBoxReplacer)
  2. Calculate the azimuth of one side of this Bounding Box
  3. Convert the original polygon to segments of 2 points (Chopper)
  4. Calculate the azimuth of every segment
  5. If the azimuth of a segment is close enough to the azimuth of the bounding box (or close enough to this azimuth +/- 90 or 180 degrees, or - if you want to - close enough to this azimuth +/- 45 degrees or +/- 135 degrees), rotate the segment around it's middle point to the desired azimuth
  6. Calculate the intersection point of every pair of adjacent segments
  7. Re-create the polygon from the intersection points
Ensure the polygons have no corners of (approximately) 180 degrees.
Make sure every original polygon has a unique ID, and use Group By on this ID where this applies.
geomancer
  • Dec 22, 2021 2:01 PM UTC
An implementation of the process mentioned above (not thoroughly tested!):
Make Rectangular_workspaceThe workspace uses a simplified version of the HorizontalAngleCalculator from FME Hub.
geomancer
  • Jan 31, 2025 9:24 AM UTC
Somebody asked me for the workspace, so I re-upload it here.
However in retrospect I think the workspace is much more complicated than it needs to be.
A lot of the initial work can be done by the PolylineAnalyzer (FME Hub).
