Is there a way to abbreviate words within a field?
  • Sep 15, 2023 4:29 PM UTC
  • 80 views
pearly1
Forum|alt.badge.img+9
imageimageHi,
New to FME and creating a workbench converting CAD to GIS. I am trying to get the structure fields to match and eventually join them after more clean up. Id like the structures field to be abbreviated. I was thinking Attribute manager could do this. but when I use conditional formatting I loose the "-#". another thought would be to add an alias? but again I am not too sure of a solution.
Thanks!
raymondbrunner
Forum|alt.badge.img+11
Have you considered the StringReplacer?
I would replace the occurrence of "Curb Inlet " (with a space included) into "CI-"
imageThis would leave the second record without a number suffix unchanged.
Forum|alt.badge.img+63
And as an addition: the StringPairReplacer will let you specify multiple replacement pairs.
