is it possible to work with FME and AGOL to run processes on the data that is hosted there?
  • Dec 17, 2021 8:05 PM UTC
  • 70 views
fme_can_do_it
Forum|alt.badge.img+13
I have a python script that I want to know how to run in FME that way so I don't have to manually trigger it? Any advice would be greatly appreciated.
Best answer by hkingsbury
FME has its own readers/writers that can work with AGOL Data - https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/arcgisonlinefeatures/arcgisonlinefeatures.htm
You may be able to jsut use standard FME transformers to achieve what you're aiming for.
If you do need the python, have a look here - https://community.safe.com/s/article/using-arcpy-for-fme-feature-processing
hkingsbury
Forum|alt.badge.img+73
  • Dec 18, 2021 5:37 AM UTC
fme_can_do_it
  • Dec 21, 2021 8:33 PM UTC
Thank you!
