is it possible to change the name of a column in a shape?
  • Feb 20, 2023 3:43 PM UTC
  • 120 views
solene01
Forum|alt.badge.img+3
I am new to fme, I set up a processing chain to compare two shape files and I would like the output file which will be a renamed shape of the columns.
for Example the file checked I have a column called depth_1 I would like the export ca to be depth_upstream.
is this possible in fme ?
  • Feb 20, 2023 4:08 PM UTC
You can indeed rename output columns in FME, but note that Shape files are limited to max 10 characters for column names.
solene01
  • Feb 21, 2023 1:59 PM UTC
Thank you for your response
Yes indeed I had forgotten this limit.
So I was thinking instead of trying to directly integrate the data into the database. Knowing that I do not know, however, if it is possible to connect this column depths to upstream depths.
