is it possible to avoid reading all features but the ones specified?
  • Sep 2, 2021 11:49 AM UTC
  • 98 views
Hi all,
My question is regarding performance actually...
I'm going through a process of reading data (shp) trimming it, doing change detection and writing it to a sde. Some of my data contains 5.000.000 objects, so it takes forever to run it, which is not a problem in production mode.
In the testing fase, when tweeking and changing settings it is a big hazzle though. I have added a tester to both my original data source and the revised data source to filter out a small portion of data, but it still has to go through every single object when reading the data...
So my question is: Is there a way to avoid having to read everything from both datasets?
Best answer by nielsgerrits
One way to do this is to use a polygon to select only a part of the data in test.
This can be done with FeatureReaders, first read the polygon, then read the data with a spatial filter.
This will work by default for SDE, the shape set will need a spatial index tho, but you can do that using FME (Esri Shapefile Parameters, Write Spatial Index).
nielsgerrits
Forum|alt.badge.img+67
  • Sep 3, 2021 6:22 AM UTC
Hi Niels,
Thank you for your answer - sounds like a sensible solution, I will give it a try :-)
Thanks
