Intersector or LineOnLineOverlay not working as expected
  • Nov 20, 2021 4:31 PM UTC
  • 8 replies
  • 136 views
boubcher
Forum|alt.badge.img+11
Hello there
Just wondering why intersector and lineOnlineOverlay transformer are not giving the expected result
even when the 2 features are intersecting
Attached is Data in shapefile format
Festure intersect
connecter
Forum|alt.badge.img+10
  • Nov 20, 2021 4:52 PM UTC
Hi @boubcher​ ,
I try your file with the newest beta and I don't have any problems:
imageI get the same result with LineOnLineOverlayer & Intersector. What result do you get from the TopologyBuilder?
Which version do you use?
danilo_fme
Forum|alt.badge.img+58
  • Nov 20, 2021 8:15 PM UTC
Hi @boubcher​
I had sucess with the version FME(R) 2021.0.1.0 (20210404 - Build 21313 .
Transformer Intersector:
Intersector
Thanks in Advance,
Danilo
boubcher
  • Nov 21, 2021 5:45 AM UTC
@danilo_fme​
Thanks for your replay
you are right, it's working when the source data is shapefile, but when it's GDB , it's not giving the same result
check the attached GDB for the same data
Please take a look
connecter
  • Nov 21, 2021 9:46 AM UTC
Hi @boubcher​ ,
in your gdb-file you don't have line objects only:
imageWhen you convert it to lines it will work:
danilo_fme
  • Nov 21, 2021 11:21 AM UTC
@danilo_fme​
Please take a look
Thanks your data.
I check the geometry from gdb is not line. Is necessary convert Arc to Line as @connecter​ worte bellow.
Thanks in Advance,
Danilo
danilo_fme
  • Nov 21, 2021 11:22 AM UTC
Hi @boubcher​ ,
Nice job @connecter​ ! :)
boubcher
  • Nov 21, 2021 4:23 PM UTC
thanks, guys you are right
IS there a way we could convert the ARC to line geometry
hkingsbury
Forum|alt.badge.img+73
  • Nov 21, 2021 9:27 PM UTC
