Intermittent issues connecting to SQL server database
  • Sep 13, 2023 2:40 AM UTC
  • 202 views
naveen
Forum|alt.badge.img+7
We are seeing an intermittent issues with connecting to database from FME workbenches ( That runs on FME server ) though the database is healthy
FME Server 2021.2.6
Build 21821 - win64
The error message is "Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147216072'. The error message from ArcObjects is: {Underlying DBMS error[HY109:[Microsoft][ODBC Driver 17 for SQL Server]Invalid cursor position No extended error.]}"
Any ideas on how to investigate this further ?? Thanks
j.botterill
Forum|alt.badge.img+69
  • Sep 13, 2023 8:46 AM UTC
j.botterill
  • Sep 13, 2023 8:48 AM UTC
Question Detail (safe.com)
Problem: Corruption in the SDE Registry. Article Detail (safe.com)
Solution: Delete the faulted objects with ArcCatalog
