Implementing image thresholding (Otsu's method) with PythonCaller
  • Dec 14, 2022 12:02 PM UTC
  • 169 views
Hello!  I'm trying to implement Otsu's method of image thresholding on an incoming raster, using the PythonCaller transformer.  I  have the following code block in the PythonCaller parameters, although my Python isn't great, so there may well be issues with it:
import fme
import fmeobjects
import numpy as np
class OtsuThreshold(object):
    def __init__(self):
        pass
    def input(self, feature):
        #implement Otsu thresholding in native Python with numpy
        #get the image from the feature
        image = feature.getAttribute('image')
        #compute the histogram of the image, then find the peak of the histogram
        hist = np.histogram(image, bins=256, range=(0, 256))
        maxVal = np.max(hist[0])
        maxLoc = np.argmax(hist[0])
        #perform Otsu thresholding
        T = maxLoc
        thresh = np.where(image > T, 255, 0)
        #set the attribute value
        feature.setAttribute('image', thresh)
        #pass the feature on to the next transformer
        self.pyoutput(feature)
I am getting this error, seemingly within histograms.py within numpy itself:
Python Exception <TypeError>: '>=' not supported between instances of 'NoneType' and 'int'
A little digging hints that this may indicate that the raster is being read as None values, which I can seemingly confirm by inserting the following before the "hist" array:
        if image is None or len(image) == 0:
            # handle empty image
            # for example, you could return an empty feature
            return
This is where I hit a dead end though.
Ideally I would like to return the actual Otsu threshold pixel value itself as an attribute, although I don't think my script it currently capable of that.
Thank you!
dustin
Forum|alt.badge.img+36
  • Dec 14, 2022 12:37 PM UTC
I don't have any experience working with raster data in python, so take this with a grain of salt....
It appears your raster is stored on an attribute, so it's possible that you are attempting the raster calculations on binary data instead of the actual raster. I would consider using a RasterReplacer prior to the PythonCaller to extract the raster from the attribute as the feature geometry, and then perform the Otsu processing on that.
