IGDS Version 7 text range calculation with Font Resource
  • May 10, 2013 7:54 PM UTC
  • 94 views
FMEers,
I'm using FME2012 to create IGDS V7 symbols, from a resource file (.rsc), for example, font 85 OCT032 50 feet by 50 feet.  UORS / FT= 381
The output range block is not correct in MicroStation.  The y-extent is fine, but the x-extent is about 30% too short.     I believe this is causing FME not to calculate the correct lower-left origin of the symbol from the insertion point.
Text-nodes (type 7) appear to have the correct range block and so do "normal" text strings, type 17, font=0.    It appears that the symbols are the only things with a screwy range block.
Anyone know how FME does symbols?  Tips, tricks, suggestions for getting the right output?
Brad
fmelizard
Forum|alt.badge.img+22
  • May 10, 2013 8:03 PM UTC
In the case of some CAD formats, there are specific styling transformers that handle symbology.
For Bently products the DGNStyler has a range of parameters concerning symbology.
Hope this helps.
  • May 10, 2013 8:21 PM UTC
No luck with DGNStyler.  It doesn't do anything with text.
fmelizard
  • May 11, 2013 10:50 AM UTC
How about the text adder? if configured correctly the proper text size can calculated  in the transformer or taken form the parsed data.
  • May 13, 2013 4:30 PM UTC
No luck with TextAdder either.  It appears to be in the IGDS 7 writer.
