IF statement based on published parameter SQLCreator
  • Mar 6, 2023 2:05 PM UTC
  • 63 views
dustin
Forum|alt.badge.img+36
In a SQLCreator, I want to return the records from a specific table, if a certain choice is made in a parameter. I have a published parameter "check_choice", that is a Choice Multiple Parameter.  In this example, I want to return table records from BUILT_UP_AREA_S if 'BUA_Road_RTY' is selected in the parameter. The database type is Microsoft SQL Server Non-Spatial (JDBC) in my SQLCreator. The statement below results in an error Incorrect syntax near ','.
What am I doing incorrectly in this statement?
IF($(check_choice) LIKE "%BUA Road RTY%",SELECT * FROM dbo.[BUILT_UP_AREA_S])
Best answer by dustin
Turns out I was over-complicating. The statement I was looking for was:
SELECT * FROM dbo.[BUILT_UP_AREA_S] WHERE '$(check_choice)' LIKE '%BUA%'
dustin
  • Mar 6, 2023 2:26 PM UTC
