I want to Validate Attribute Continuity
  • June 6, 2022
  • 10 views
mukhtarg
Forum|alt.badge.img+4
Hello Experts,
I have two polyline files. Both have name attribute . The condition of validity is if the line name is in continuity then its valid, if not then its invalid.
image.pngimage
danilo_fme
Forum|alt.badge.img+45
  • June 6, 2022
Hi @mukhtarg​
I suggest you to use the transformer LineCombiner.
There is a configuration to merger lines that has the same value : Combine On Attributes
And you can enable the option to create a List of elements - for make a count os pieces of lines connected with differents value attribute.
Thanks in Advance,
Danilo
