I want to calculate distance from aspect and slope on a raster. Both raster have same resolution. Could someone help on this? I am novice on raster dataset in FME. Thank you in advance.
  • Nov 28, 2021 10:10 PM UTC
  • 95 views
hkingsbury
Forum|alt.badge.img+73
  • Nov 28, 2021 11:48 PM UTC
I'm struggling to get what you mean by "distance"... Can you explain the problem in a bit more depth?
  • Nov 29, 2021 12:19 AM UTC
I am try to distance from attached formula.
hkingsbury
  • Nov 29, 2021 2:54 AM UTC
I think I follow with what you're trying to achieve... Are you wanting to get the length of a line overlaid on a 3d surface?
If thats the case there is a much easier approach, assuming that you have a DEM of the area (this wouldve been used to derive the slope and aspect)
Use your DEM to create a surface, then using the SurfaceDraper, drape the line features over the surface so they have Z values, then use a length calculator with the dimensions set to 3 to calculate your length
