I need to clip lots of rasters and use them as 'images' only. I don't want to keep any wordfile or locational data. Is there a way to remove this?
  • Feb 3, 2021 11:42 AM UTC
  • 77 views
I have a points shapefile, I buffer the points and use this to clip VRT Rasters. I need the output to retain the attributes passed from the point/buffer, which the clipped output does. However the clips retain georeference and place the clips within total images footprint if that makes sense. I tried converting to PNG (no world file option chosen) which works great but this loses all the attributes. Grateful for any suggestions.
Forum|alt.badge.img+63
The CoordinateSystemRemover transformer removes coordinate system but leaves everything else intact.
  • Feb 3, 2021 3:00 PM UTC
I tried that but doesn't seem to do what I need.
jdh
Forum|alt.badge.img+41
  • Feb 3, 2021 6:46 PM UTC
Option 1, write to a format that doesn't support embedded georeferencing and set World File Generation to No.
Option 2, RasterGeoreferencer, withPointAndAngle, set the coordinates to 0,0 and the spacing to 1,1.
