I'm trying to create a self service FME Server workspace app, that will accept, as an input, either a shapefile or an FGDB feature class. Is this possible?
  • Jun 7, 2022 6:34 AM UTC
  • 180 views
oihdosj
I want to be able to present the user with a single input option that will accept either a shapefile or an FGDB feature class. It doesn't seem possible to me because:
  • the generic reader doesn't seem to allow you select an FGDB
  • I can't have a shapefile reader and an FGDB reader in my workspace, but only use one
Am I really going to have to create 2 workspace apps, one that processes shapefiles and one that processes FGDB feature classes?
FME Desktop 2021.2 and FME Server 2021.2.
Best answer by david_r
Thanks @david_r​. So, if I understand you correctly, I need a (required) published parameter to identify whether the user is going to upload a shapefile or an FGDB, then 2 (optional) published parameters for the shapefile/FGDB file paths?
User Parameters
That could be one way of doing it. Or you could support a single zip file, then check the contents of the zip file in FME (you can point a FeatureReader using the "Directory and File Pathnames" reader to the zip file) and redirect to the appropriate reader, depending on what you find inside.
  • Jun 7, 2022 6:47 AM UTC
You don't have to use the generic reader, simply use two different FeatureReaders, for example:
imageThat said, I'm fairly sure the generic reader is able to read a FGDB.
oihdosj
  • Jun 7, 2022 9:07 AM UTC
User Parameters
  • Jun 7, 2022 9:53 AM UTC
User Parameters
oihdosj
  • Jun 8, 2022 7:20 AM UTC
User Parameters
Thansk. I'll try that out.
