I have some old JAVA files from a discontinued Java based program. The file extensions are .jar and .class. The data is basic line, point, and polygons with attributes. Is there any process I could convert these files to ESRI shape or geodatabases?
  • Oct 17, 2023 7:19 PM UTC
  • 72 views
johnspears
Participant
hkingsbury
Forum|alt.badge.img+73
  • Oct 17, 2023 8:15 PM UTC
I don't know Java, so this could be completely wrong. Have you opened the files in a text editor (Notepad++, VSC, or even Notepad) and had a look to see if there's something that resembles spatial data?
If so you can read the files in FME with the Text File reader and begin to filter out unneeded data and rebuild the geoms.
johnspears
Participant
  • Participant
  • Oct 17, 2023 10:28 PM UTC
Thank you hkingsbury ! I'll give it a try.
  • Oct 19, 2023 10:19 AM UTC
I would expect the .class files to contain Java code as plain text, and not any data. The .jar files are basically renamed zip files and you can unzip them to see what's inside, perhaps there are some more common data files within, e.g. shapefiles.
