I have a fairly simple problem but can't seem to figure it out. I need to copy one excel file to another folder and rename the copied file. I've tried using the PATH reader and the File Copy Writer but nothing seems to get copied. Any ideas?
  • Aug 7, 2021 9:04 PM UTC
  • 8 replies
  • 594 views
mcannalea12
itsmatt
Forum|alt.badge.img+48
  • Aug 9, 2021 7:16 AM UTC
The path reader and File Copy writer is definitely the way to go. Try using an attribute manager to set the specific attributes needed for the file copy writer - use the 'path_windows' as the 'filecopy_source_dataset' and set 'filecopy_dest_filename' to be the new filename (just the filename, e.g., mynewname.xlsx).
Β
For the output location of the FileCopyWirter set the folder you want the new file in.
Here's a little more info: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/filecopy/Feature_Representation.htm
mcannalea12
  • Aug 9, 2021 2:28 PM UTC
Thank you, I finally was able to get it to copy and rename something, so progress! Unfortunately, it's not an excel file - in fact I can't even tell what kind of file it is. I've included a screenshot of the file it creates, along with my path and file copy parameters. Is something off? I thought filtering PATH to just grab excel files might fix the issue but it doesn't seem to be working.
mcannalea12
  • Aug 9, 2021 2:30 PM UTC
Edit: I switched the screenshots up, path parameters are on the right, not the left.
mcannalea12
  • Aug 9, 2021 4:30 PM UTC
Oh my god, crown me Supreme Idiot. I wasn't putting the file extension in the new file name. I was putting "Archive_Test" instead of "Archive_Test.xlsx".
itsmatt
  • Aug 10, 2021 7:02 AM UTC
It looks like you're very close. The file just seems to be missing it's extension. You will need to also specify that in the new filename. So Archive_Test.xlsx should be the new file name.
itsmatt
  • Aug 11, 2021 6:12 PM UTC
🤣🤣 - Glad you got there in the end!
riad.hamoudi
Can you share an example of a workbench? They're driving me crazy 😀
I have about 3000 JPEG photos that I would like to rename using a field, with the new photo name.
riad.hamoudi
Finally, my colleague from the office, who has more experience with FME, let me know that my output fields were not selected, see point 4 in the photo. It’s working now. Merci
Β
