I have a csv file where I want to calculate the sum of a respective attribute which have the same ID. In the example below I want to sum the values of v2 and add it in the correct place for id = 22, then go onto the next "group", thanks!
  • Oct 12, 2023 11:14 AM UTC
  • 6 replies
  • 295 views
id,v1,v2,v3,v4,v5
22,hi,hi,1,2,3
22,hi,hi,1,2,3
22,,,,,
33,hi,hi,2,3,4
33,hi,hi,2,3,4
33,hi,hi,2,3,4
33,,,,,
44,no,no,5,5,5
44,no,no,5,5,5
44,no,no,5,5,5
44,no,no,5,5,5
44,no,no,5,5,5
44,,,,,
Best answer by nielsgerrits
I probably do not understand what you need. Can you add you expected output?
I still do not understand why one would want this :D but the attached workspace produces what you asked for.
nielsgerrits
Forum|alt.badge.img+67
You can do this using the StatisticsCalculator. Group by id.
  • Oct 13, 2023 9:04 AM UTC
Thanks! But how do I place the values found in the empty columns in the final row of each "group"?
nielsgerrits
  • Oct 13, 2023 9:07 AM UTC
id,v1,v2,v3,v4,v5
22,hi,hi,1,2,3
22,hi,hi,1,2,3
22,,,sumv2,summv3,sumv4,sumv5
33,hi,hi,2,3,4
33,hi,hi,2,3,4
33,hi,hi,2,3,4
33,,,sumv2,summv3,sumv4,sumv5
44,no,no,5,5,5
44,no,no,5,5,5
44,no,no,5,5,5
44,no,no,5,5,5
44,no,no,5,5,5
44,,,sumv2,summv3,sumv4,sumv5
nielsgerrits
  • Oct 13, 2023 9:25 AM UTC
  • Oct 13, 2023 11:22 AM UTC
Thank you very much! Is part of a larger system which has its requirements, odd as they may be.
